Up Topic Welding Industry / Technical Discussions / Alloy X750 to Alloy 600
- - By Tim Buyle (**) Date 05-04-2001 06:46
I am looking for a suitable filler material to weld an Inconel 600 flange to an Alloy X-750 tube. Welding proces GTAW.
Parent - By G.S.Crisi (****) Date 05-04-2001 13:14
X-750 is also an Inconel alloy. Get in touch with the manufacturer, who knows his products better than anybody else and will be able to help you. The data:
International Nickel Inc.
Park 80 West Plaza Two
Saddle Brook, NJ 07663
Phone (1) 201-368-4800
Fax (1) 201-368-4858
Site: www.inco.com
If you're not from the USA, on the site you'll find who's INCO's representative in your country.
Parent - By pdweldor (*) Date 05-04-2001 17:50
Inconel 82 (ERNiCr-3) will work just fine.
Parent - - By MBSims (****) Date 05-08-2001 03:56
Isn't X-750 the precipitation strengthened alloy? Can you weld it without growing the precipitate size in the heat affected zone and having reduced yield strength? I've never heard of anyone welding X-750, but that doesn't mean it isn't being done. It would be advisable to contact INCO Alloys techical support before welding.
Marty
Parent - By pdweldor (*) Date 05-10-2001 15:54
Yes it is a PPtn strengthened alloy, and yes you will loose strenth in the HAZ, but the welded joint strength will still exceed the strength of the Inconel 600.
