Some of the heat treatable aluminum alloys loss considerable strength and ductility when they are welded. Even if they are solution heat treated after welding, they do not regain their original properties.
6061-T6 aluminum is just one of those that are degraded when they are welded. The minimum allowable tensile strength, if AWS D1.2, B2.1, or ASME Section IX are the governing documents, is 24 ksi. The failure is typically in the HAZ adjacent to the toe of the weld.
The laboratory most likely machined the samples to produce a rectangular cross section. They are suppose to retain some of the root pass if they follow the requirements of the welding standards mentioned above. As a point of information, some welding standards require the bend samples to be machined to 1/8 inch thick if the test piece is thicker than 1/8 inch. The machining requirements of both the tensile test and bend test samples have to be monitored to verify it is done properly.
It would not surprise me that your customer approved them. They may not have the expertise in-house to do a proper review. They depend on the supplier to be cognizant of the requirements and they review the paperwork to see that it is in place. They then look at the certifying statements at the bottom of each document, i.e., the PQR, WPS, and WPTR, if the certifying statement reads that the tests were prepared, welded, and tested in conformance with the applicable welding standard, their assumption is that they meet all the requirements including the required NDT (if any) and the mechanical properties.
In my humble opinion, the people that placed their signatures on the present welding documents have been fraudulent. Any welders qualified to the current WPS are not properly qualified or certified. If this work is for a federal, state, or local government, or if the work is covered by a building code or OSHA, or included in the Federal Register (shipboard pressure piping and pressure vessels) then there could be criminal legal repercussions if something fails in service.
Lawyers just love to follow the paper trail when something goes crunch or boom in the middle of the night. They bring in their technical experts to review calculations, test reports, welding documents, QC reports etc. to see who was responsible or who didn't do their job properly.
Trust me, you don't want to be the subject of a deposition or on the witness stand trying to explain why you didn't follow the requirements of the purchase order or contract specification if someone is injured or killed as a result of a product failure. Even if you did everything correctly, if is not a comfortable situation to be in.
If I were in your position, I would not hesitate to bring this matter to the attention of "upper management" and recommend that the procedures be requalified as well as the welders to make sure everything is on the "up and up" under your watch. You can't do much about what was done in the past, but you can influence the present and future. As for the laboratory that did the original testing, I would think twice about using them in the future.
A word of caution: It has been my experience that many laboratories do not use the correct bending mandrels when bending anything other than 3/8 inch thick carbon steel samples. For the purposes of internal audits and to provide an additional comfort level for my customers, I always include the dimensions of the test samples and the bend radius (or diameter) of the mandrel used in my reports. You might consider using AWS B2.1 Specification for Welding Procedure and Performance Qualification and AWS B4.0 Standard Methods for Mechanical Testing of Welds as the basis of your welding program and laboratory testing if you are not working to any specific welding standard. Make sure the lab doing the work has in-house copies of the reference documents, i.e., include a reference to AWS B2.1 and AWS B4.0 in your purchase order. In some cases the problem with the testing performed by laboratories is not entirely their fault. For instance, if they are simply asked to "bend test these samples" and they are most familiar with API requirements, which uses the same bend mandrel on all thicknesses of materials, you can expect they will not meet your expectations when testing to something other than API. The misunderstand can easily be that the testing regiment is not clearly stated in the purchase order or work order. Make sure you order the proper tests and reference the proper welding standards when you subcontract the laboratory work. If you don't understand the requirements, don't expect the laboratory to. If you need to hire a consultant to set up your in-house program, do so. It will be a worthwhile investment for your company and your easy of mind.
I commend you for doing your homework and discovering the problem.
