The Arc Force was invented with the welder's needs at heart...
- Developed to give the welder complete control over the intensity and consistency of the arc -
- Developed to prevent busting a test -
Essentially, Arc Force is a set of shunt coils that replaces the standard shunts in the generator. Unlike regular shunts where you use 100% of the coil all the time, Arc Force is multitapped; and allows you to select different levels of intensity and drive. The system is controlled by a special switch installed to the control panel; and ranges are numbered 1 through 5. The number 5 being maximum, or 100% coil usage. The beauty is that you can switch between ranges while you are welding!
Now, think about this...
You currently have 5 heat ranges on your machine, adding the Arc Force gives you 5 heat ranges for every range on the range selector switch. 5 x 5 = 25 heat ranges!
We can even expand that to 35 heat ranges if a 7-Selector sytem is installed!
