Hi Andrew,
That's a lot of questions, let's go in order. Keep in mind these responses are gleaned by *Subjective* observation.
The statement I made about the benefits of increased frequency in Hz applies to thin aluminum at low amperage only, For example, to get maximum accessibility to fillets ( Lets say 0.063 to 0.032 in 6061 T6) we have moved away from balled electrode tip prep. With a water-cooled torch and a full length Zirtung you can select a 1/16in or .0.063 diameter electrode with something like 75 degree included angle and an ever so slightly blunted tip. The effect we find most appealing is the (Conical arc), the arc appears to constrict and become much more directional as the frequency in Hz increases up to the afore mentioned 220 or so. The Extreme adjustments in balance control (up to 90% dwell time) the aerowave affords along with the independent power on each side of the AC half cycle (NOT available on the Dynasty) can really extend the capabilities of an electrode.
On heavy aluminum operations Miller suggests lower frequency in Hz. I agree, but my practical experience here is a bit more limited. The Dynasty goes as low as 20 Hz compared to the Aerowaves 40 Hz. This is great on heavy castings where it may be impossible to achieve the purity to weld DC straight on the heavy stuff. A puff of Helium can also extend performance when you're taking things to the limit. The Dynasty also has a more limited duty cycle, but the only time we have made the thing reset was during a training session in an attempt to find the limits of the machine. I'm gonna wait another year to further evaluate durability before a strong recommendation of the Dynasty but for now I will say that Its amazing to have a 250 Amp AC/DC Tig machine with all the options that I can pick up myself and put on the work bench.
On a more theoretical note. We have begun to experiment on scrap stuff, welding AC on Steels with Aerowave settings toward the maximum on penetration and straight polarity such as 80 amps Straight 20 amps Reverse balance to 90% penetration, AC frequency adjusted to between 300 and 400 Hz. When these parameters are applied to alloys such as Inco 718 or Hastelloy X, alloys in which operators usually observe what is called a *muddy pool*, this phenomina is seemingly etched away by that slight puff of Reverse polarity. You can actually see the oxide being etched from the filler wire as you dip it in, and yes we use clean wire in the first place :). Post weld visual examination will reveal a lovely wetting at the toe of the weld, which cannot be gotten by DC straight. The drawback of course is more heat input as a result of the Reverse polarity. The welder can bring the bead profile back to size with a quicker pace. What may or may not be going on at the micro level I'm going to keep propriatary because we have just not taken enough time with it to come to a conclusion that has any authority behind it.
Will you find parameters difficult? That depends on what you do. We are in the repair business so we see a great diversity of projects and very few production jobs that we can come down with exact, repeatable settings for such a machine. The Aerowave set on the normal settings that any other TIG machine might provide still excels them, switching so cleanly between + and - that High Frequency is not even employed. If you have a crack staff they will rise to the challenge and enjoy what your new machine has to offer… However we do have other folks who dislike the complicated nature, and rightly argue that most jobs do not require a Star Wars welding machine and are quite happy to stick with the ever trustworthy synchrowave 250
Lanthanum as a replacement for Thorium is fine, We have found Lanthanum to outperform all comers in the automated TIG arena for hand welding they are adequate but its not a real noticeable difference from Thorium. Try several brands before you settle on a vendor, some will bend rather than break or fracture lengthwise. I have been told that different vendors use different powder metallurgy methods making the things. So performance may vary greatly. I would NOT recommend Lanthanum as an acceptable AC electrode, low amperage arc stability being the chief problem.
I've tried before to get this topic going in the forum, Lets hope others will break open the treasure chests and share some of their wealth. I would sure like to know what other folks have experienced with this technology.
Enjoy
Lawrence
"Human law must rest its authority ultimately upon the authority of that law which is divine....Far from being rivals or enemies, religion and law are twin sisters, friends, and mutual assistants. Indeed, these two sciences run into each other.
"James Wilson, a signer of the Constitution and an original Justice on the U.S. Supreme Court
