Up Topic Welding Industry / Technical Discussions / Welding 5083-H323 Aluminum
- - By 1fastguy (**) Date 02-06-2008 14:57
We just got a contract to build some parts that are made for 5083-H323 Aluminum. We have never welded on this type of material. We are used to T6 6061 Alm. I would like to know what the biggest difference in welding this material is? Filler rod suggestions, shielding gas, difficulties, recomendations, experience, etc. I was thinking 5356 rod and 100% Argon. We will be using GTAW at the material is .125 thick. Any help would be useful. Thanks
Parent - By Kix (****) Date 02-06-2008 15:28
Yeah thats high strength marine grade weather resistent aluminum correct?  We use it on our aerial booms. 5356 is a good choice of filler and 100% argon for .125 thickness will do just fine and if you can weld 6061 t6 then you can weld this stuff.  Whats the application for?
Parent - - By GRoberts (***) Date 02-06-2008 15:39
While 5356 is metallurgically compatible with 5083, (i.e. it shouldn't hot crack), it is lower strength.  If you need matching strength, use 5183, and if you get too much dilution &/or a low alloy content batch of wire, it can still come in under strength.
Parent - - By vantage500man (**) Date 02-06-2008 17:31
I have used mini spool gun with .035.. 4043 wire with pure argon on 6061 and 5086 for boats and have had no problems so far.. I would like to here if any body out there if they have had any long term problems with this wire used an stronger metals. I have had no problems with cracking or any other issues so far thank you
Parent - By 1fastguy (**) Date 02-06-2008 17:49
Thanks for the input.
