Up Topic Welding Industry / General Welding Discussion / Actual Weld Cycle Times
- - By APM (*) Date 02-14-2008 20:27
I need to know if anyone has a spreadsheet or table that has actual weld cycle times for the following GMAW weld process: Spray Transfer
Actual weld time for fillet welds that are equal to or greater than 1/2 inch or 12mm. The times need to be based on welding in the horizontal position 0 to 15 degrees using .045 diameter solid ER70S-6 wire. The table or spreadsheet needs to include at a minimum a wire feed speed range of 350 to 550 IPM.
Parent - By Sean (**) Date 02-16-2008 00:14
How many passes - likely not a single pass with this size of wire?  What material thickness(es)?  What size of part?  What type of cleaning is being done in between passes, if any?  Is there a maximum interpass?  All of these things will affect weld cycle times.  Not to mention the folks that track this information (i.e. have the spreadsheet(s)) you are looking for likely will not want to share the information as it relates directly to their productivity and costs...
