Well, different codes have different tests to get you certified down to 1" and 2" without actually testing on 1" or 2". They call out different tests on a particular size of pipe that will get you certified in a range of diameters and thickness. If you test on what you will actually be welding on like a stainless tubular turbo mani you would need to take a 6g 1" sched 40 full penn (penetration) pipe tests. You could take other tests that will certify you down to 1" sched 40, but this way you don't need to reference a code. I say this because you will be good for all positions in case you can't flip the mani around and position it and I say full penn in case whoever requires full penn welds. If they don't require full pen then your still good. If you take a test and certify for partial penn then you won't be certified if the place needs you to do full penn welds. Hopefully you smell what I'm cooking here. I guess t spell it out for ya, if you bring a place that welds stainless and steel tubular mani's the test I told you to take would probably get you in the door. If you bring them a 2" cert that would probably get you in the door as well. A lot of times the certs you have are only good just to get you in the door only to have them give you s test they need you to take. Your cert shows them that they won't be wasting their money giving you their test that is needed.
