Up Topic Welding Industry / General Welding Discussion / 2'' open butt 7018 root
- - By Leo27 (*) Date 02-24-2008 03:08
never done it need help
Parent - - By welder5354 (**) Date 02-24-2008 06:24
What's your question?
Parent - - By Leo27 (*) Date 02-24-2008 14:27
what land and gap you should take and heat on a sa 200
Parent - By NDTIII (***) Date 02-25-2008 04:32
Try using 6010
Parent - By aaronshermer Date 02-25-2008 14:39
Try the same set-up as a 6010 joint on your 7018 joint (nickel land and 1/8" gap). In whatever position you are welding in, your tack preperations will be the difference in if you pass it or not.....
Parent - - By Kix (****) Date 02-25-2008 16:09
Do a search on 7018 open root and you will find plenty of info on this particular process.
Parent - By lynx Date 02-27-2008 03:15 Edited 02-27-2008 13:32
3/32 land gap and rod,  Arc voltage (dig) @ 65-70. Straight polarity amperage approx 75-85 amps or set your heat in reverse pol and run a stringer in the vertical on plate. When running your root try to keep a 1/16-3/32 gap between your keyhole and rod while maintaining light constant pressure on the rod. Rod is kept perpendicular with a slight leading angle. I have used these peramiters in the past and they have always worked in my favor.
Dean
