How do you run 1/8" 7018 fill/cap passes on 6" sch 80 pipe in the 5G position? can you weave it? or does it have to be stringers? and don't read into this question too deeply...I'm just talking about walking into a shop, somebody asks you to weld this 6" sch 80 pipe w/ a standard ASME IX B31.3 fit-up with a 1/8" 6010 root and the rest 1/8" 7018. I'm asking about rod angles, amps, travel speed with reference to the rest of the weld (you weld kinda slow on the bottom, faster from 5:30-3:00, medium speed on the side, and slow on top...that kinda thing), and any other tricks you guys might have.
