Up Topic Welding Industry / Technical Discussions / ut compression wave scanning on aluminum
- - By petethomas Date 05-17-2001 14:10
anybody know the velocity of ut comp waves in aluminum alloy 6053 or similar
simple answer preferred
regards pete
Parent - By pipewelder_1999 (****) Date 05-17-2001 21:44
Try this site
http://www.ndt.net/article/az/ndtmain.htm
Parent - - By Jorge Giraldo (**) Date 06-07-2001 23:52
Dear Pete:
I have the following data that may be usefull:
Alluminium: Transversal Wave Vel. (Vt) = 3,08 m/s
Longitudinal or Compressional W. V. (Vc) = 6,32 m/s
Al-Cu Alloy: Longitudinal Wave Vel.=3,10 m/s
Longitudinal or Compressional W. V.= 6,25 m/s
The following formulas can help you:
Vt= (E/(2p(1+u)))^(1/2)
Vc= (E(1-u)/(p(1+u)(1-2u)))^(1/2)
Where:
E is the Young Modulus (N/m2)
p is the material density (kp/mm2) (1kp/mm2= 0,98x10^7 N/mm2)
u is the Poisson's ratio (dimmensionless)
As you can see, the sound velocity depends of the material properties such as E, p and u, so I do not expect a big variation in the compressional wave velocity for different Alluminium Alloys.
I hope this help you.
Jorge Giraldo
MedellĂ­n, Colombia
Parent - By petethomas Date 06-12-2001 08:11
Jorge
I would like to thank you on behalf of my colleague who was actually requiring the info, in his words " it was everything he needed"
once again Thanks
pete
ps tried email direct but it got returned
