You need an exothermic electrode which has been designed for chamfering, grooving, and gouging of all metals. You can use( Magna 100) is the ideal electrode for your job because the coating has insulating materials so that it does not get over-heated even though the electrode is used at high amperages. And Magna 100 makes a U-shaped gouge which is ideal for welding.
