We are using Dual Shield wire (Lincoln G80M with C25) on pipe (16" to 24") all day long every day here outside, in the wind, snow, rain and mud. For bad weather we use HexHut tents strapped on the pipe, if it is calm out we seem to be abe to get away without much shelter. Very little porosity has shown up so far and minimal if no other weld defects due to the wire process. We are doing the root and hots with 8010P1 though. Most guys have Miller Extreme VS machines (supplied) but some have Lincoln LN25s. Both seem to work just fine. A guy could be doing open roots with hard wire anywhere but the fitup would be a more critical. Fittings to pipe typically have a lot of high-low here and hand prepped tie ins also have a lot of varriance in gap/land/bevel/high-low. Wire roots on the bottoms would be more difficult no? I don't have a lot of experience with hard wire on open roots. Does anybody do it out in the field? STT maybe would be more valid in that case.
FCAW on pipe????
1) First and foremost in a word....TRADITION!!! (Grandpa never wire feeded no pipe!!!!)
2) Bulk of the wire feeder, draging from place to place, is a major pain. Also consider having to keep contact tips and other spare parts handy, it just can't compete with the lightweight portability of a stinger and rod pouch when in the field.
3) When using a FCAW or GMAW gun, one of the main things is to try and maintain as straight of lay out for the liner assymbly as possible. Due to the inhehent necessity to articulate the angle of the gun on a fast and continuous basis, this is not a good choice for small to medium diameter pipe in a fixed position...say under 24". Nothing is more frustrating than putting in a X-ray root bead and having the wire start sputtering and splattering right on the tie-in because you had to put a kink in the cable to get a proper angle of the dangle to reach that point!!!
OK, with all that being said, a wire feeder strategically placed (overhead or at least elevated off the floor) on 1G pipe (manual roll out wheels or power driven rollers) GMAW root and fill or even GMAW root with FCAW fill & cap (killer pound's per hour production on heavy wall), will kick "A" in production shop envirnment over SMAW.
Bucyrus Erie, the maker of the worlds largest draglines GMAW 0.045" their booms. The booms are a lattice design of 10" & 20" pipe with about 2" wall thickness. Root penetration is 0- 1/32" max, and the entire welding process is under continuous UT and other NDE surveillance. These machines operate under phenomenally severe environments. > 100 F in the summer and < -40 F in the winter. The point sheave of the boom on a B/E 2570 walking dragline would be about 350' from the operator, with a cable and bucket assembly including payload supports in the neighborhood of 300 tons and swinging hundreds of cycles per 24 hrs, day after day. These are not gentle swings and payouts of cable like setting a 300 T load with a Mantiwoc Ringer, but HAULIN' "A"!!!!
So, yes, semi-auto processes can and are used in field work on critical pipe components!
I personally am not a fan of these processes in the "pipe trades" out of a shop and stationary, controlled environment. Just too many things to go wrong.
Thats my story and I'm sticking to it!
One more thing from your post, cranking up the gas flow often causes sheilding problems due to excessive turbulance sucking in air. Years ago when I was a mine maintenance welder, we used a lot of FCAW-G in the field. Some locations like load out chutes under the silos with intense natural air flows made for some long and frustrating shifts battling the wind vs. gas coverage............
