all chopper machines have it now . It helps stack when using cellulose rods (7010 , 8010 etc. ) when pipelining . play with your settings and burn it on some pipe downhill and try it. regular cc stick setting is good for everything else
hope that helps you
Jesse
Hey Vman, I have the 400 and used it this past Saturday on some light wall 12" for the first time. It doesn't have the quality arc that the Miller TrailBlazer 302 with it's aircooled 3600 rpm motor has but it still welds very well. Leave the arc force on "0" like the manual says and have at it. Arc force set at -2 and there are issues with keeping the arc lit. Arc force at +2 and it doesn't seem as smooth. Spent the last two days welding TDW short stop fittings and welding 1" street plates. Just for SH@TS and GiGGLES I tried to stick a 3/16 6010 in the plate and had to push really hard to get it to stick- Ted
