![](/mwf/attachments//avatars/13260-9338.jpg)
After taking a welder qualification butt weld test on pipe in the 6g, I can only find where it says you can weld fillet welds on plates of unlimited thickness. (note1) I can't find if it says you can weld grooved plate of a certain thickness if it even says it. Thanks for any info on this subject.
