No just leave it as is and if you are already above or below the manufactures recommended amperage then don't go any more above or below. 95amps for a 3/32 electrode is freekin hot. Why even run that 3/32-rod, just go to a 1/8" rod right after the 6010. Your still legal if you do that because it's only a jump of .03 in size and your allowed to jump .8 in size. If you write another WPS then you can use the manufacture recommendations and then you know not to go above or below that.
