When weld joint is between a pipe and a plate with CJP required.The pipe(beveled) is perpendicular to surface of the plate. Is this joint a T-connection? A welder is qualified with 6G can weld it or not?
T-K-Y connections are a generic term that describes tubular/pipe connections where branch members are welded to a main member, or chord, at a centering point.
