Up Topic Welding Industry / Technical Discussions / TIG welding with gas rods
- - By mattinker Date 03-07-2008 11:05
Hi,
I read recently that mild steel rods for oxy-acetlene should not be used for TIG welding, could somebody tell me why!
Thanks, Matthew
Parent - - By Lawrence (*****) Date 03-07-2008 12:58
I believe the oxy-fuel filler rods are not deoxidized to the extent required for GTAW.
You will have a greater chance of experiencing sputtering and porosity if you attempt GTAW with oxy-fuel filler.
Parent - - By mattinker Date 03-07-2008 16:28
Thanks,
Matthew
Parent - - By aevald (*****) Date 03-08-2008 09:14
Hello mattinker, As usual, Lawrence is spot on with his to-the-point explanation, one small additional consideration when comparing the two different filler rods might also include tensile strength differences, generally RG45 (oxy/fuel) filler rod, has a strength rating of 45,000, ER70S-2 or 3 or 6 (GTAW) filler rod, has a strength rating of 70,000. My $.02. Best regards, aevald
Parent - By mattinker Date 03-09-2008 11:30
Although I've been welding (ark and oxy-acetylene) for the last thirty five years, I'm new to GTAW . Last week I bought myself an SAF nertabloc 250 TIG. So now I've got to get myself some rods together! As I've got a stock of gas rods I was wondering about using them hence my question.
Thanks for your reply, Matthew
