Up Topic Welding Industry / Metallurgy / 201SS vrs 441SS
- - By MikeO Date 03-07-2008 11:47
I'm looking at changing from 201SS to 441SS, food service application (shear, punch, bend, weld). Any good stories, any NIGHTMARES?
Parent - By gwg (*) Date 03-08-2008 02:34
MikeO;
I would suggest you do a little research on this. Type 441 ss is a ferritic stainless that is commonly used in higher temperature applications, like heat exchangers and exhaust manifolds. I would suggest you look at 444 ss for your food processing.
The 201 stainless steel is an austenitic stainless that work hardens but it is susceptible to chloride stress corrosion cracking.
Parent - By MikeO Date 03-11-2008 18:13
thanks
