Up Topic Welding Industry / Inspection & Qualification / Weld test
- - By jelliott Date 03-08-2008 01:54
I have been giving weld test for a company for awhile now and I have been using there QC program which is asme section IX.My ? is were can I find what test I'm suppose to give.For example I give a 2" sch 80 tig on carbon steel pipe.Were can I find if this info is correct.Also were can I find out if I can give one test that qualifies more than one test.Example if I take a test on 2" stainless pipe does this certify me on carbon pipe.
Parent - By pipewelder_1999 (****) Date 03-08-2008 03:07
ASME Sec IX has all of the information.
ASME Sec IX will let you know what diameter qualifies for what diameter. What filler metal qualifies for what filler metal etc..
I would ask the company if you could look at it sometime. It will tell you about your stainless question.
Gerald Austin
http://weldingdata.com/
