Up Topic Welding Industry / Inspection & Qualification / Welding in the 6GR position
- - By djts Date 03-10-2008 07:39
A tubular framing plan (Brazing - Tubulars) - for a offshore structure which includes TKY joints. The majority of the framing plan will be welded in the fabrication shop which could be rotated to maintain the 1G position - offshore the framing plan will be fixed. Do the shop welders require to be 6GR qualified for the fabrication shop welding.Offshore since the tubular structure will be fixed -- then requires 6GR welders.
Parent - By jon20013 (*****) Date 03-10-2008 09:16
I'm thinking it depends on the Code / Standard used.  In my particular application, we're required to work to EEMUA Standard and 6GR is a requirement in this application.
