Up Topic Welding Industry / Technical Discussions / arc welding mc on cnc
- - By ashish jain Date 03-11-2008 13:39
dear sir,
I want to use arc welding mc for tig process on cnc mc (no hf,no lift arc) whether it is possible.
secondly inverter base mc have any adverse affect on cnc mc.
pl suggest
ashish
Parent - By DaveBoyer (*****) Date 03-12-2008 05:22
I have no direct experience, but offer these suggestions:
Make sure all the controll and machine tool chassis grounding wires have good connections at both ends.
Rout all welding cables away from position sensers, controll boxes, and the wiring between them.
Atach the welding ground directly to the work, or to the fixturing if You can not atach to the work. Never hook to the machine tool.
