To bad its not that simple, if you mean A-6 tool steel. Very high carbon is not welder friendly.
You can weld with many types of filler but a procedure requires more info on what you got, what you gotta do and what you want to end up with.
Can you use Brazing (Silver Solder) instead of welding?
