Up Topic Welding Industry / General Welding Discussion / JOBS!
- - By BIGMWELDING Date 03-17-2008 20:53
DOES ANYONE KNOW OF ANY WORK IN OR IN SURROUNDING AREAS OF OKLAHOMA, I.E. ARKANSAS, MISSOURI, KANSAS, NORTH TEXAS??
Parent - - By KSellon (****) Date 03-17-2008 22:18 Edited 03-20-2008 14:49
Pipe, pipe and more pipe. Too many to list this late in the evening. I will try tomorrow.
DZ Atlantic has a nuclear shutdown in Nebraska. Don't need you to use your rig they supply all. Paying 400 for your expenses to get there and 400 when you go home. $28 an hour, 70 Prdm, 6-12's
Parent - By BIGMWELDING Date 03-18-2008 19:27
OK, THANKS, WILL BE WAITING, MY WIFE AND I ARE TRYING TO GET CLOSER TO HOME.
Parent - - By Robert Turney (*) Date 03-20-2008 02:00
There are quite a few jobs in Arkansas in the Fayetteville shale play.
Parent - - By weiser1876 (*) Date 03-20-2008 02:46
Where i have called i thank allmost every one that i have worked for and no one is hiring at the momet try back in may seen alot of welding trucks in wilberton ok no one would even say high dont know if it is a seckret work or what like to know I havet had 40 h in over 3 months fixing to eather sell out or go to work for the local welding shop as a single hand and ride the bike to work weather is getting good agen taking a trip to dallas tx this weekend and check it out
Parent - - By mody454 (**) Date 03-20-2008 16:34
whats in dallas?
Parent - By weiser1876 (*) Date 03-20-2008 18:27
Family and hope some work that payes I Have be wating on some checks for over a month now kinda getting mad going to check out hanson pipe agen talked to them about a year ago and got a little work from them not much
Parent - By BIGMWELDING Date 03-25-2008 22:41
DO YOU HAVE ANY NUMBERS??
Parent - By Kix (****) Date 03-20-2008 17:18
Union work or just work?
Parent - - By weiser1876 (*) Date 03-20-2008 19:47
LOOKING FOR pipewelders, pipe fitters, must be willing to travel to and in Southern louisiana ask for russell 18665183837 19858766778
Parent - - By wannaweld (*) Date 03-26-2008 02:09
weiser1876,
What about helpers?
Parent - - By weiser1876 (*) Date 03-26-2008 03:05
Call I did they are trying to get numbers for the job they said that they dont even have the work order yet just something i saw in the paper hear in eastern ok
Parent - - By jonesythebrit (*) Date 03-26-2008 03:47
is that the job for CLP?
Parent - - By weiser1876 (*) Date 03-28-2008 20:52
I Rilly Dont know  What is CPL
Parent - - By jonesythebrit (*) Date 03-29-2008 00:16
Attention Pipe Welders: Immediate Job Openings
Journeyman Pipe Welders
Job Description: New construction on a gas terminal located in southwest Louisiana (project to last thru August).  Housing is available close to the jobsite at a rate of $260/week (2 beds).  The nearest hotels are 10-12 miles from the jobsite and start at $300 weekly.  Tradespeople that perform well on this job will have the option of continuing to work with this customer on their next project.
$26/hour
$100 a day per diem
$200 Weld Test bonus
$500 Bonus for every 1,000 hours worked
Safety Bonus
Completion Bonus
Weld Tests (must pass all three tests):
Test 1:   2" Sch. 10 Stainless Steel Tig all the way out on 6G (visual only)
Test 2:   Pipe 4" .625 wall Carbon Steel Pipe. Tig Root and Stick Out on 6G (visual and bend test)
Test 3:   Pipe 2" .625 wall Carbon Steel Pipe. Tig all the way out on 6G (visual and bend test)
Call 1.800.819.0251 today to apply!
As a CLP Project Trades Solutions employee, you won't have to look for work - we'll do that for you!
We'll keep you working, project to project.
APPLY TODAY!
1.800.819.0251
CLPtravelers.com
Parent - - By weiser1876 (*) Date 03-31-2008 21:40
OK they did not say any thing about union other than that just call
Parent - - By jonesythebrit (*) Date 04-01-2008 05:06
it's not a union job, as far as I'm aware
Parent - By Cactusthewelder (*****) Date 04-06-2008 00:56
Patterson UTI Drilling is hiring Rig Welders in Tyler TX. Need to talk to Raymond Bond $60.00 pr. hr. The # is 903-877-3848
Parent - By LINCOLNCHIC (**) Date 06-26-2008 12:53
Are yall still lookin for pipe welders? If so are yall needing contractors, or single hand? Also, which part of south La
Have a good one....LINCOLNCHIC
