i'm certified with lh root, used it alot on the rigs in the north sea/Scotland and Norway, great way to run a bead when you get used to it and your right the Kobe is a great rod. Another realy good LH rod/electrode is the Pillips 56s (7018), nice and smooth for a LH. Don't forget a nice wide open root gap on a 6" in 6G, slightly wider at the top than the bottom, thet test piece will close on you other wise, and there will be nothing you can do about it. Especialy with LH's.
WELL DONE ON THE FIRST CERT! keep it going.
