Up Topic Welders and Inspectors / Welding Equipment Classifieds / doors
- - By er3welding (*) Date 03-20-2008 02:19
how is it going i would like to know where is a good place to find a set of doors for my sa200 86 model thanks for any help
Parent - - By weiser1876 (*) Date 03-20-2008 02:34
It will probley cheeper to have them broke and find some 3/16" pipe to make the hindges i priced some SS doors and a hood for about $350 hard thing to find is the latches ill look in the barn and see if i can find a set good luck
Parent - By raftergwelding (*****) Date 03-20-2008 02:44
you can get latches from lincoln for around 16$ each the new doors from lincoln are 300 each yeah cheaper to have a set broke used 1's are going for 100-150 a door
Parent - By KSellon (****) Date 03-21-2008 13:52
Stumpf Welding Supply in Illinois Set of doors with all hardware (hinges, latches, etc) brand new and better than factory.  http://cgi.ebay.com/LINCOLN-SA-200-WELDER-DOORS-SET_W0QQitemZ320195888983QQihZ011QQcategoryZ113743QQtcZphotoQQcmdZViewItem
Parent - By jim parker (**) Date 03-23-2008 03:54
I can make you a set with no paint or latches for $200.00 per set.
