Up Topic American Welding Society Services / Technical Standards & Publications / Tack Weld Positions per D1.1
- - By castle (*) Date 03-20-2008 13:07 Edited 03-20-2008 13:16
Would I be correct in my interpertation that according to 4.18.1.2 (D1.1), if I tested a tack welder in 2F, then he is only qualified for 2F.  Would Table 4.10 in D1.1
be nonapplicable to tack welders?
Parent - - By jrw159 (*****) Date 03-20-2008 14:11
My interpretation of this is the same as yours. I do not believe that table 4.10 is applicable to tack welders.
Parent - - By castle (*) Date 03-20-2008 16:24 Edited 03-20-2008 16:29
So if table 4.10 does not apply to tack welders, and taking 4.19.2.1 into consideration, would the tack welders be able to tack a CJP butt joint that is to be welded from one side
and backgouged and/or a backing weld on the back of the joint then filling the rest of the joint from the front?
I understand 4.19.2.1 if it pertains to open root CJP and T-,Y-,K-connections.
Parent - - By jrw159 (*****) Date 03-20-2008 16:49
Thats the way I read it.
Parent - - By castle (*) Date 03-20-2008 21:55
Thanks jrw159.
Parent - By jrw159 (*****) Date 03-21-2008 13:02
Anytime, glad to help.
