I would start with the adjustable inductance control at zero (if machine has it). Start with the voltage at 17-19 (which can be measured with a voltmeter (handheld or meters on machine)). Voltage controls the arc length and the height and width of the weld deposit. Than I would adjust the wire feed speed which determines the amperage (can be measured with meters on machine or hand held tong meter) which determines the penetration. I would then increase the voltage or decrease to get the arc length for the desired metal transfer mode. Remember, weld procedures call out amps (wire feed speed may be referenced), volts and travel speed of the arc. These can be measured and recorded. Sounds like - cannot be measured.
Set the adjustable inductance control to fine tune the short circuit metal transfer arc and weld deposit. Spray transfer, adjust this control to prevent burn back to the contact tube.
