Over the years, I've seen a few Pipe Supports Engineering Standards issued by engineering companies that show the flat bar welded directly on the pipe, as you describe.
This is not a good engineering practice. The flat bar should be welded to a rounded plate ("rounded" means that the plate matches the pipe's shape), which in turn is welded to the pipe.
