Up Topic Welding Industry / Technical Discussions / pre-heating on LTCS
- - By Richman (**) Date 04-03-2008 13:49
WPS use in the project we undertake states the pre-heat temperature shall maintain to 93 °C if the thickness is more than 25mm for LTCS pipe. In case these requirements throughout our inspections did not meet or follow before and during welding process (GTAW+SMAW) , is there any effect on the weld or weld metal after completion of welding considering there is a PWHT required for this joint or spool?
Parent - By js55 (*****) Date 04-03-2008 15:34
LTCS = Low Temp Carbon Steel?
How thick is the material?
Parent - - By Richman (**) Date 04-05-2008 04:12
Around 30mm WT is the spool others is thicker than I mentioned.
Parent - - By Richman (**) Date 04-05-2008 04:14
Sorry I forget to say the material is LTCS
Parent - - By js55 (*****) Date 04-07-2008 14:38
What does the LTCS stand for?
Parent - - By Richman (**) Date 04-08-2008 04:03
Low temperature carbon steel
Parent - By js55 (*****) Date 04-08-2008 13:23
Preheats based upon thickness requirements are strictly for H2 cracking control. If there is no evidence of cracking you will find that your microstructure is probably even better suited to the service. Preheats slow down the cooling rate and help minimize shrinkage stresses, and evolves H2 out of the material. But this slowing down of the cooling rate runs counter to the what you actually want with low temp carbon steels, and that is a refined microstructure that demonstrates good low temp impact toughness.
If you have no cracks, you should be fine.
