Up Topic Welding Industry / Inspection & Qualification / AMP readings?
- - By Mikeqc1 (****) Date 04-04-2008 14:38
When doing welding machine calibration or Calculating heat input where is the most accurate place to put the amp meter? I ask because there is a minor dispute on where to take this reading from. Any opinions on this?
        Mike K
Parent - - By aevald (*****) Date 04-04-2008 18:55 Edited 04-04-2008 19:07
Hello Mike, this booklet may help you with some of your questions. I haven't read through it for quite some time now, but as I recall it is fairly comprehensive and may be of some help. Best regards, aevald
     Mike, I tried to attach a Calibration Booklet from Miller, but unfortunately I couldn't do so because of the size of the pdf. file, it was too large to attach. If you would consider PM-ing me and giving me your email address I can send it to you that way if that works for you.
Parent - - By Mikeqc1 (****) Date 04-04-2008 19:04
Did you send a link, i dont see a book name or website?
Parent - By jrw159 (*****) Date 04-04-2008 20:04
Mike,
  I have attached the booklet in my earlier post.
Parent - - By jrw159 (*****) Date 04-04-2008 19:09
What happened Allan??
Attachment: CALIBRATIONBOOKLET.pdf (0B)
Parent - By aevald (*****) Date 04-04-2008 23:10
Thanks for getting that attached. One of these days I might truly figure out all of this cornpewter stuff and be able to do everything that I want to with them. Best regards, Allan
