Before you go any further, I'd make sure the specification you quoted is not a typo. If it is not, then check with the people who wrote the spec. to assure it was intended to be those numbers. If that is the case, then your spec is an engineering document, you've chased it as far as you need to chase it.
However; I'd be very much surprised if you could find any stamped er308 that didn't meet the ASME requirements.
regards,
Gerald
