Up Topic Welding Industry / Welding Fundamentals / i need help
- - By slb4175 (*) Date 04-09-2008 00:31
i have a weld test on friday 4-11-08 for the ua 430
the test is a 2in 6010-7018
any advise
seth
Parent - - By Billyjoe (***) Date 04-09-2008 01:52
What you want to know?
Parent - By Stringer (***) Date 04-09-2008 04:02
take your time. keep it cool. this coupon heats up really fast.
Parent - By bbwinc (**) Date 04-10-2008 22:58
What is the sch? This is my game plan, I'm guessing it's 160 put a good land on the pipe , good tacks ones that will match the root when your done. After you lay the root in ,grind it clean then put the hot pass in with a small weave if any. Then fill up the joint with clean stringers , I put the cover on with 3 stringers. Then it's miller time!! Good luck man i hope it goes good for ya!!! p.s. make sure you start the rod clean every time and that test i use 3/32 5p and 7018 rod all the way out. Good luck!!!!!
