Ok, im trying to respond to several posts in one here... so bear with me.
Welderdude, yes you are correct this is sprinkler piping. Most of it is sch 10 but ive run into a bunch of sch 40 allredy. Ive set it as low as i can get away with and still have it solid when im done, and the first patter i tried was the one you described. the fittings still seemed to pull out of square and when i switched to the pattern in the sketch they seemed to get better. I notice them tweak out more with smaller fittings, around 1 to 1 1/2, over the larger ones im welding which are around 2 to 2 1/2. Any clues as to why thats happening would be grand...
also, im gonna sound dumb.... but whats a jewel clamp? is that like a bessie clamp?
Tommy! Good to hear from you, hope everytings well on your end. Ive been swamped between school and work...
You have some sound advice there, but i really hope that the whole pipe isnt bending from the tiny 1 1/2 inch outlet i welded on one end. That would open up a whole new can of worms. Ive used that trick of pre-bending parts before, it defently works and it has totally saved my arse many a time... i was just hoping that i wouldent need it and before you and others mentioned it, the thought hadent crossed my mind. Bending a 3/16 post over a 4/4 with a few bessie clamps was tricky enough, i really want to avoid having to figure out how to do that to a 21 foot peice of pipe...
Medicinehawk, patg, if i can figure out how to get the 2 tabels i have available to me to work on together and level and such, ill try and get a strong back setup... im olny using a singe chain clamp on a relitivly small tabel at the moment to hold the pipe from rolling and throwing off my level when im working on it. not the best of setups but im new, im still claiming my territory so to speak ;)
johnnyh, i havent the slightest clue if its a butt or a fillet. i look at it and see 2 peices of steel coming together at a 90 (around the fishmouth anyways...) and that seems like a fillet to me. but im also not up to speed on all of the pipe welding lingo. I didnt draw it too well in the sketch.. i think i might borrow dads digital camera and see if i can get some pictures of what im workin with for all to see.
Ok, im too tired to spell/grammer check this post... and i really need to shower...
Thank you all for your replies and experience :)
Goodnight
-Clif
These are branch connections (ASME lingo) and the welds are usually complete joint penetration groove welds unless the fittings are relatively small diameter. If the fittings are beveled, CJP is the typical requirement and they require a reinforcing fillet over the CJP groove weld. The size of the fillet is dependent on the specific code requirements. Please note that the operating pressure is not a variable, i.e., weld size is independent of the pressure rating.
As for the joint type, they are simply called branch connections. Small diameter branch fittings can be half couplings that are either fillet welded to the run pipe or they can be beveled and welds just like any other bevel groove detail. Large diameter branches or branch connections, larger than 1/4 the diameter of the run pipe (header to some), typically require an integrally reinforced branch fitting (a "weld-o-let" to some). A typical welded branch of the "Weld-O-Let" variety looks more like the sketch to the left. The sketch to the right is sometimes referred to as a "stab in" (an other case of slang). Please bear in mind that the size of the reinforcing fillet weld in the sketches may not be the same size as those required for your project.
As for the distortion; you can pre-spring the pipe as already mentioned or contrary to some suggestions, use as few passes as possible to fill the groove to reduce the "thermal history", that is reduce the number of thermal cycles where the base metal or previous weld experiences thermal excursions above the lower transformation temperature (about 1330 degrees F). The last suggestion is to weld an "X" on the run pipe (header) opposite the branch fitting that is equal to the diameter of the branch fitting. The idea being that the "X" will cause sufficient residual stress to counter the residual stress caused by welding the branch fitting. Multiple passes over the "X" will increase the forces developed and will minimize the deflection caused by welding the branch fitting.
Al, I can only look at one of the sketches you posted because I don't have a CAD program to open the other 2. :( If you can get the other 2 in the .wmf format then I can see what you're cooking. :)
Thank you for providing the correct terms for what I'm working with. The "weld-o-let" is what I'm using at work, and there all about 1/8 to 3/16th thick and pre-beveled. I'm not sure they would let me weld an X on the header, but if I keep having problems i'll ask them.
Welderdude, were almost on the same page. The pipe I'm working with is larger than hand rails, anywhere from 2 to 4 inch OD sch. 10 to sch 40. But other than that you're right on the money. Water tight and square to the pipe is what I'm after. Water tight is easy; getting it square after I'm done zapping it is proving to be the hardest part of the job. Any idea where I can find a jewel clamp, somehow I get the feeling that "home defect" doesn't have it...
I've been practicing it more and I found a new patter that is working pretty dang good. I start at 6 and go to 3 then 6 to 9 then 12 to 9 and then 12 to 3. I've been leaving the level on the piece of threaded pipe I use to adjust it while tacking the fitting in place and I can watch the heat from the welds pull the bubble around.
Thank you all for your knowledge and time :)
-Clif
Both sketches are the same, different formats.
The "X" can be done with GTAW torch. The intent is to "spot" heat the back side of the run pipe. The greater the delta T, the better the draw. You can use an oxy-acetylene torch, but the heat is too dispersed to get the benefit you would get with a GTAW torch.
Point of information: the bevel and root face of the "Weld-O-Let" are to be "dressed" to properly fit the run pipe. Some welder are under the impression they are ready to use as purchased. That isn't the case. They have to be hand fitted to provide the proper root opening and bevel.
a jewel clamp is like the chain clamp you're using now, but it has 2 chains on it for clamping 2 pieces of pipe to keep them aligned until you tack weld them.
I know exactly what you mean when you say sprinkler pipe. pretty much it's like welding a handrail. and you work in a production shop, so all they want is threaded and victaulic fittings welded on so they'll hold 120 psi and they're square to the pipe and they want it done fast. your best bet might be to pre-bend the pipe. find out how much you have to bend it and make yourself a spacer to put under the fitting you're about to weld on. then clamp the pipe down on both sides of the fitting. that might be the fastest and easiest way to handle it.
Plasma-brain, a pair of vise grip 11R clamps with a 2" piece of angle iron welded to them and a small length of channel iron makes for a cheap jewel clamp.
Something else that works slick is take the stainless portion of a no hub band used for connecting cast iron plumbing pipe and you can use it to fit the joint, you can also cut a window in for holding internal purge. It works good on diary tube and schedule 10 stainless.
