Up Topic Welders and Inspectors / Welding Equipment Classifieds / pipe grounding rig???
- - By jwelderman24 Date 04-12-2008 02:19
Is there a company that makes pipe grounding fixture?    magnetic base with spring loaded contact arm?  or does any body have pictures of what they use?
Parent - By uphill (***) Date 04-16-2008 02:04
Go to www.sumner.com  they have a nifty clamp on rotating ground that you can buy replacement parts if needed. Otherwise tweco and Western make magnetic grounds. I got a pair of Westerns they seem to work out OK. The tweco ones are about 1/2 price but dont look like they are vee'd out on the contact area.
Uphill
