Up Topic Welding Industry / General Welding Discussion / 76,sa 200/2" sch 80 5p r,8010 out the setting will be on it
- - By Leo27 (*) Date 04-14-2008 00:16
what would be the place to start
Parent - By 357max (***) Date 04-14-2008 03:00
Set the range selector high so the fine current adjustment will be near zero for the desired amperage. This will provide a low open circuit voltage arc which provides a digging/forceful arc. When the range selector is low and the fine current adjustment is near maximum the open circuit will be highest. This is a good setting for the XX18s. Measure the open circuit voltage and verify the high and low.
Parent - By banshee35 (**) Date 04-14-2008 16:43 Edited 04-14-2008 21:24
not sure about 8010's, but with 1/8 6010's  I'll run in the 190 range and between 40-50 on the fine adj.
