Up Topic Welding Industry / Technical Discussions / whats the difference in SA333 GR.6 and sa106 Gr.B
- - By okieplott (*) Date 04-14-2008 20:58
i have never used SA 333 gr. 6 pipe. we use 106 or 53 most of the time does it weld any different or is there is difference than a106 b i seen there both P1 G1. and 60 tensile
Parent - - By 803056 (*****) Date 04-14-2008 21:28
From what I can see, SA333 is a carbon manganese steel (some grades have some nickel), but the weldability should be the same as SA106 or SA53.
Parent - - By js55 (*****) Date 04-14-2008 21:33
You won't be able to tell the difference by looking at it. 333 is a fine grained carbon steel material and comes with specified impact testing, since 333 is for low temp applications.
Parent - - By js55 (*****) Date 04-14-2008 21:35
If you have an impact test regime 333 is the way to go, though not for nukes.
Parent - By okieplott (*) Date 04-15-2008 15:00
thanks for the info
