If you intend to look at Arc welding you need at least a No# 10 filter but whats the point? If you are not with in inches of the work you will maybe see a pin point of light only.
If you do only Oxy-Fuel welding / cutting a No# 6 is good but the same as above applys.
If you darken the glass a few shades (No# 3) plus far enough away and do not stand and stare at the arc you might get the effect you want but is it worth liability?
Inform your Office Manager that welding is not a spectator sport and the eye damage (flash burn) is very painful.
