Question nÂș 7.
The equivalence of hardness units (for example Rockwell to Vickers, as you say, or Brinell to Rockwell) is only approximate. There are a quite a few equivalence tables around (I've got 2 or 3 in my personal library), and the good and honest ones always state that they're only approximate and are to be used for information purposes, never for precise calculations.
The best table I know of is the one contained on the SAE Handbook.
I'll generally be talking about CA6NM, but I don't see why it wouldn't apply to F6NM as well.
1- There are generally two types of PWHT, as you probably already know. CA6NM Class A get a PWHT at 1125+/-F. CA6NM class B gets a PWHT at 1250+/-F, followed by cooling and then re-heating to 1125+/-F. The cooling before the 1250F and 1125F are very important. I haven't seen any research regarding how far to cool, but MIL specs say room temperature, and ASTM says to cool below 200F. Also some people specify a slightly higher temperature than 1250F, such as 1265F.
2- The target of the double temper is obviously to get below 23 HRC. You can do that on a regular basis if you know what you are doing. If not, it can be hard to get. A typical single temper PWHT might yield you results in the 23-28 HRC range.
3- Interim cooling is definately critical, but the actual temps seem to be debated.
4- No personal experiance with this.
5- Not generally. If you use GMAW/GTAW, it seems to be easier. If you use FCAW or SMAW, you need to use a manufacturer that has good knowledge and regular practice in meeting the NACE maximums- that is as important if not more than the C level, because not only is the C level of the consumable important, but the flux formulation as well.
6- You do have to have a lower carbon content max than any of the AWS specs call for. I think most people call for a .03% maximum because it is easier for the filler metal manufacturers to meet, but a well known and highly respected material expert at a major manufacturer is a proponent for .02% max C. (I think he even has dropped by this BB a few times)
7- A alternate conversion is required, but I got out of the CA6NM business before I had to do much vickers, so I didn't have to deal with that specific one. The excellent metallurgist I worked with developed her own data for converting brinell to HRC (for base metal), as the standard conversions are not accurate.
8- I haven't seen any particular Ni limitations. Obviuosly the intent would be to raise the upper and lower critical temperatures to allow for a higher PWHT temperature. The trade-off will of course be reduced toughness.
