Up Topic Welding Industry / Technical Discussions / er70s-6
- - By cwi-cws (*) Date 04-27-2008 01:02
can someone give me info on er70s-6 (gmaw) i dont have  my a5.18 spec. i need to know if it has limits such as material thickness,electrical,position.the pros. and cons. thanks in advance.
Parent - By PhilThomas (**) Date 04-27-2008 03:36
I'm not sure that A5.18 is the right document...not much of what you want is in there.....but:
No limit on thickness (from a weldability standpoint, NOT a WPS qualification standpoint)
Typically run with reverse polarity
Can be run all position with short arc or pulsed arc
The -6 indicates a higher level of deoxidizers (Si) vs the S-2 or S-3.
