Standard results if you test heat treatable (P/S/M23 or F23 for example) aluminum alloys in a standard plunger and die type bending machine.
It is unusual that the lab actually have the proper diameter dies. Most labs have the standard 1 1/2 inch diameter die and use it for everything.
API 1104, if my memory serves me, uses the standard 1 1/2 inch diameter for all material thicknesses and all grades of steel.
