Hi im curently testing for bsen287 coding on 6g posisition on 4 in carbon steel piping and am having problems with lack of fusion start at the start stop can you pros give me any advice im using 3/32 6011 fleet rods for root with 3mm gap and 2 mm landing edge, rest of the runs are good capping with 7018s and the slag is falling off etc, and the inside of the pipe looks like a stack of dimes with the slag peeling off, just the start stops causing problems
