Up Topic Welding Industry / Technical Discussions / GOUGING OF CAST IRON
- - By centroidindia Date 06-21-2001 13:37
Dear Sir,
Kindly suggest most suitable method for gouging of 6 inches DUCTILE IRON/ SG IRON/ NODDULAR IRON.
VENKAT
Parent - By - Date 06-21-2001 17:39
Please supply more info: Do you want to merely cut a 6" thick piece of cast iron, or do you want to "back gouge" or make a weld prep? If you want to cut it, what sort of accuracy do you need?
Niekie
Parent - By G.S.Crisi (****) Date 06-26-2001 18:25
Get in touch with Carbone Lorraine, top manufacturer of carbon electrodes for gouging.
In India, they're in Bangalore, and their telephones are: 9180-547-1405 and 9180-548-0078. Their fax is:
9180-548-0079.
They'll furnish you all the information you need.
