Up Topic Welding Industry / Technical Discussions / 7075 Aluminum
- - By Milton Gravitt (***) Date 05-07-2008 20:32
Is there any new data on the welding of 7075 alum.I've check the search and they think you shouldn't weld it.
Parent - By GRoberts (***) Date 05-07-2008 23:36
The 7xxx series aluminum are not gernally fusion (arc) welded.  However, if your application is suitable, it can be friction stir welded (or other solid state processes)
Parent - - By Kix (****) Date 05-08-2008 19:37
Usually 7075 is riveted together and not welded and is used a lot in the aerospace industry.  If you arc weld it, it will more then likely crack.
Parent - - By 803056 (*****) Date 05-09-2008 02:13
The aluminum alloy 7075 is an alloy of aluminum and zinc. The zinc volatizes during welding and it is the low melting point constituents (zinc included) that is the root of all evil, i.e., cracking.
Parent - - By Milton Gravitt (***) Date 05-09-2008 07:56
Thanks to everybody for there reply.
Parent - By Tommyjoking (****) Date 05-09-2008 09:46
"The zinc volatizes during welding and it is the low melting point constituents (zinc included) that is the root of all evil, i.e., cracking."
Al I just love how you put that!! LOL  I will use that "root of all evil" in the near future I just know it.
