You bet I am game for that John! Terminology interpretation is important even in the FC.
Porosity - another term for lightning holes, "so its not so heavy", except these are specially produced in the weld deposit to avoid unnecessary fabrication.
Inclusion- to add to the bill or job I.E. "I made an inclusion of that porosity at no extra charge just because I like you"
Stress relief- a 30 pack and a rod and reel.
Oh dang I am sorry you said NON standard terms....ok I think I got it now.
Whip it in there- 1/8" 7018 on a 12 gauge vertical pass.
Slag- a synonymous term for weld deposit when primer is handy...[see inclusion for further explanation]
Straight polarity-The weld does not appear to have been done by a homosexual person.
Negative polarity-The equipment was at fault for the defect.
Strolling out the lead-Making some xtra money
Kodack-1.something performed by someone educated beyond their intelligence 2. Working for free 3. BS its all the buddy system man!
Backup gas-Where the heck is that porta-potty...NOW!!!!
Speed glass- A mirror in the glovebox. (ok that was harsh I am sorry....well no I am not).
Press fit- Bang it and nail it.
I better lay off now, I got a tarantula to relocate you know!
Best regards
Tommy
Tommy,
Great start. All should be included, IMHO. LOL :-)
John
Acceptable weld - See Goodenuff
Arc Blow - Condition commonly encountered when welding after the chili cookoff at the state fair.
Arc Strike - Common condition encountered while performing BWAW.
Backhand welding - A training technique utilizing negative reinforcement for the help when they screw up the weld beyond the criteria for goodenuff.
backing - Your best buddy on a good night drinking at the dodropin.
burning in - Condition commonly noted after hearing the statement "hey ya'll watch this".
BSAW - if it's to far up the silo to reach, tie the stinger to a broom stick and getterdone.
BWAW - Budweiser arc welding.
Burn through weld - catching the barn on fire while welding.
Buttweld - slag that popped and dropped into the crack of your pants while welding
Buttering - showing up at sally mays place to elope with everything but her ring.
corner joint - the dodropin beer joint round the corner.
fillet weld - Non standard term for welding after a good day fishing
Full penetration weld - (censored)
dilution - The act of adding water
dip soldering - act of soldering while enjoying a dip of snuff.
Goodenuff - If the weld doesn't break on the first lift, it's good enough
Stringer bead - See BSAW.
CWI555,
"Full penetration weld - (censored)" Thats Great!!
Actually they are all great but that one is my favorite! :-)
John
