Up Topic Welding Industry / Technical Discussions / fillet weld ndt
- - By vittorio (*) Date 05-09-2008 08:32
Dear all,
I've a question regarding the requirement for inspection of a fillet weld. Materials is A516 gr 70 the type of joint is a lap joint between two plates of thk 6 mm. The plates are used as an internal lining for the bottom of a concrete basin and will be incontact with the fluid contained in the basin (sludge, water  and other oils).
The quesion is: which requirements regarding the NDT of this weld should i apply? Visual Inspection of 100% of weld an then? MPI to which extension? Any suggestion regarding standard to apply?
thanks in advance
best regards
Vittorio
Parent - By hogan (****) Date 05-09-2008 19:40
what code are you working to?
Parent - By CWI555 (*****) Date 05-11-2008 16:04
Code your working to will usually define the extent of your examination.
