Up Topic Welding Industry / General Welding Discussion / Vintage Welder, Broken Power Switch
- - By HNirider Date 05-09-2008 22:42
I have a 1968 Sears Colormatic stick machine that was my grandfathers.  The on/off switch broke and I'm having trouble finding a replacement.
It is a panel mounted, 240V, 60A, 2HP switch.  It has 2 input connections and 2 output with a chassis ground.  I'm guessing thats DPST, right?  I'm sure it's obvious I'm no electrician.
I know I can't get the exact switch, but does anyone have suggestions of where I can find a good replacement?  Local supply houses don't carry anything that big.
The only thing I can come up with is mounting a disconnect box on the side of the machine, but I really don't want to do that.
Thanks,
Hank
Parent - By DaveBoyer (*****) Date 05-10-2008 03:52
Perhaps You can get a replacement switch from Miller or Lincoln and put that in. It is a Dubble pole single throw.
Parent - By sbcmweb (****) Date 05-10-2008 04:11
Hi, Hank. Shoot me a pic of it, I may have a used one off a dead machine that looks close. Can't promise, but I'll look. Thanks Steve sbcmwebber@comcast.net. 517 202 0314
