Up Topic Welding Industry / Welding Fundamentals / downhill welding tips
- - By pipelinegator (*) Date 05-11-2008 01:33
any help with root,hp,fill and the dreaded cap,to help me conserve gas!!!!
Parent - - By Stringer (***) Date 05-12-2008 00:28
Well, you could thin your land, tighten your gap, and go for smooth starts, running all the way from tack to tack. This would tighten your bevel a bit, needing less grinding and filling so you could move on faster and turn your machine off sooner. Is this what you mean? Fuel for the machine?
Parent - By pipeliner04 (**) Date 06-04-2008 02:12
stringers right but im not real sure what your talking bout by saving gas,,,that depends on the machine,,,ol 200,,,good luck,,,,or maybe a new diesel machine like a 300d or a no iron totin vantage,,,youll really watch your work fall to pieces.  what problems are you having,,and what rod are you using,,,sounds like 70+ or hype
