Up Topic Welders and Inspectors / Welding Equipment Classifieds / Lincoln® LN-25,With Gas Solenoid, only $1,500.
- - By A.Leig Date 05-11-2008 16:15
Lincoln® LN-25 Portable Semiautomatic Wire Feeder With Gas Solenoid And Internal Contactor like new for sale only $1,500.  Sells new for $2281 at Lincoln.
This is a great machine.
The LN-25 semiautomatic wire feeder is ideal for field or construction use. Since it is powered across the arc, no control cables are needed! Simply connect the weld cable, attach the arc sensing clip, and you're ready to go.
This portable MIG and flux-cored wire feeder comes in a fully enclosed case to protect against damage on the job site. The LN-25 features a tool-less quick release mechanism for easy wire changing, and it accepts 10-44 lbs. (4.5-19.9 kg) wire packages for plenty of welding versatility.
This LN-25 is in good fully working condition, nearly new, the case is in great shape, minor scrapes as it is used. No chips or cracks.  This LN-25 does have the gas solenoid and internal contactor.  The leed and gun are a nice heavy duty Tweaco, the head is slightly worn, but in good shape, and the lead is about 14 feet long.
Read the technical details at Lincoln. http://www.mylincolnelectric.com/Catalog/equipmentdatasheet.aspx?P=421
SERIOUS INQUIRES ONLY CONTACT ME DIRECT AT ALEIG@YAHOO.COM
LOCATED IN KANSAS CITY
Parent - By tnhnt (***) Date 05-20-2008 02:12
Picked up and new one in Colorado for $1,368.00 With a solenoid and a contactor but that was with out a gun just the unit.
