Up Topic Welding Industry / General Welding Discussion / Lincoln 305G VS. Miller Trailblazer 302
- - By Fusion W (*) Date 05-14-2008 04:32
Hey guys I am looking to buy a new welder for my 1 ton I was wanting anyones opinion on the
lincoln 305 G or the miller Trailblazer 302, which one might be the better welder for the money! Thanks.
Parent - - By DaveBoyer (*****) Date 05-14-2008 04:56
Do You need AC welding output?
Parent - - By Fusion W (*) Date 05-14-2008 05:12
No not really, but it would be nice if I ever needed it.
Parent - - By 357max (***) Date 05-14-2008 14:00
Go with the Trailblazer 275 DC and if AC is needed plug an AC/DC inverter into the 240 VAC receptacle.
Parent - - By Fusion W (*) Date 05-15-2008 04:25
Never thought about an inverter, thanks for the input! curious if a DC engine drive has better arc performance than a AC/DC drive?
within the caliber of welders we are talking about!
Parent - - By DaveBoyer (*****) Date 05-15-2008 05:10 Edited 05-15-2008 05:52
In all modern machines this size, they are all a rectified alternator for DC weld output, but the Trailblazers use a 3 phase 120 HZ alternator for the weld output, and that rectifies into a really smooth DC weld output. Conversly, the guys with the Lincoln "chopper" machines seem to like them just as much.
Parent - - By Fusion W (*) Date 05-15-2008 23:02
Thanks for the info Dave, greatly appreciated!
Parent - - By JHarlos (**) Date 05-16-2008 00:00
I have a 302 for a back up and I will put it on the truck for a stainless job. I dont know about the 305g, but you want have any problems with the 302.
Parent - - By Fusion W (*) Date 05-16-2008 02:56
What are you using as your main welder J-ROD?
Parent - - By Fusion W (*) Date 05-16-2008 04:15
I hear the lincolns with chopper technology are pretty smooth but not sure if they are any smoother than the 3 phase millers.
Parent - - By JHarlos (**) Date 05-16-2008 20:52
sa 200
Parent - - By Fusion W (*) Date 05-17-2008 02:02
seems like everyone is looking for a sa 200, are parts hard to come by?
Parent - By JHarlos (**) Date 05-19-2008 03:39
Parts, not really, just finding would be more of a problem
