Up Topic Welders and Inspectors / Education & Training / Vaccume assembly Flange orbital welding
- - By TheSavvy1 (**) Date 05-14-2008 22:37
Does anyone have any suggestions on where I could purchase or build some purge fittings for KF Flanges?
Also if anyone could add any input in regards to weld fixturing for vaccume assemblies would be appreciated.
Parent - - By ssbn727 (*****) Date 05-15-2008 06:30
Intercon, Huntington, Dissolvo, Aquasol, are few names that come to mind... Here are some links:
These are water soluble:
http://www.users.qwest.net/~apcompany1005/?gclid=CMjUkofFp5MCFQQcHgod1W-d5A
http://www.dissolvo.com/welding_instructions.php
http://www.dissolvo.com/pdf/pamphlet.pdf
http://www.aquasolcorporation.com/Home/NewsandEvents/AquasolWaterSolublePaperandTape
http://www.aquasolwelding.com/techtalk/
http://www.aquasolwelding.com/products/
Here are some articles on purging:
http://www.airproducts.com/NR/rdonlyres/6AC2C3E9-40E1-4E21-8BBC-57CA2F3E27CE/0/stainless_pipe.pdf
http://www.haynesintl.com/pdf/h2065.pdf
http://www.thefabricator.com/Consumables/Consumables_Article.cfm?ID=1401
http://www.thefabricator.com/TubePipeFabrication/TubePipeFabrication_Products.cfm?ProductsID=263
http://files.aws.org/wj/2006/12/wj200612/wj1206-38.pdf
http://www.sperkoengineering.com/html/Purge.pdf
Here's orbimatic's purging accessories:
http://www.orbimatic.com/orbital-welding-accessories/orbital-welding-accessories.html
These guys are good:
http://huntingdonfusion.com/HFT/
http://www.gowelding.com/met/purging.pdf
http://esvc000163.wic028u.server-web.com/catalogue/SPW%20Section%201%20Purging.pdf
Another good source:
http://www.intercononline.com/welding/welding.htm
http://www.intercononline.com/welding/paperman.htm
Here are some more companies offering purging dams and some ideas one could use to build their own but then again, liability issues might bear fruit choosing that route especially in critical applications so, a word of caution may or may not be appropriate here:
http://www.rubcons.com/saf/products_safety_purgedams.php3
http://www.orbitalwelding.com/Pages/07-Purge.htm
http://www.pipelinesupply.com/moreinfo.cfm?Product_ID=453105929&CFID=6444772&CFTOKEN=277
Here's an interesting article from the NRC:
http://www.nrc.gov/reading-rm/doc-collections/gen-comm/info-notices/1993/in93063.html
Another on that's interesting to say the least:
http://www.cns-snc.ca/branches/Bruce/challenges.pdf
Here's an article emphasizing the seriousness of the necessary safety factors required in order to avoid accidents such as these types:
http://www.hss.state.ak.us/dph/ipems/occupation_injury/reports/docs/94ak012.htm
Very cool oxygen measuring/monitoring equipment used when purging:
http://www.tendringpacific.com/pdfs/products/SGI-3,%20OXI-3,%20ISM-3%20Oxygen%20Indictors.pdf
AMI, Mathey Dearman, Orbitalum (Formerly George Fischer), Magnatech, Orbitmatic, Cobra systems of of California, Astro Polysuede or something like it, Swagelock, etc...
Do a google search and you will find what you want. I'm going to hit the rack!!!
Parent - By TheSavvy1 (**) Date 05-16-2008 04:09
Great links
Thanks,
